Re: Wheel Stands
[Re: maximum entropy]
#1116698
11/22/11 07:40 PM
11/22/11 07:40 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
a twelve second car that wheelies is more fun than an eight second car that doesn't. it's been proven.
well i drove 12,11,10 & 9 and i have news for ya,your wrong! why the heak do you think theres such a demand for chassis shops and good engine builders?
Re: Wheel Stands
[Re: Kindafast]
#1116699
11/22/11 07:43 PM
11/22/11 07:43 PM
fishy340
LONG ISLAND
If you look real close to my pic you will see my lft front tire up just a little. I would personally love to carry the hoops as high as wheelsup , but at my age I would probally poop my pants.
lol
Re: Wheel Stands
[Re: fishy340]
#1116700
11/22/11 08:51 PM
11/22/11 08:51 PM
Posts: 20,668 in a cattle trailer down by th...
Guitar Jones
As promised, here's a pic of my car. Only the third pass on this combo and oh geez, I'm so clueless I'm at the division finals. Car is on the bars hard here too, you do know what those are don't you?
Re: Wheel Stands
[Re: Guitar Jones]
#1116701
11/22/11 09:00 PM
11/22/11 09:00 PM
Guitar Jones
Yep, see those bars sticking out the back with the little wheels? They are called wheelie bars and are used to tune the chassis and keep the car from scraping the bumper, smashing the oil pan, bending suspension components from insane wheelstands, wasteing ET and generally making a fool of yourself. But I digress...
Re: Wheel Stands
[Re: Guitar Jones]
#1116702
11/22/11 09:04 PM
11/22/11 09:04 PM
Guitar Jones
And BTW since you think your Dart will run circles around my leaking junk, I'll stick a piece of junk converter here I have in it and you can come on down to sunny Florida and GRAB A LANE! Oh yeah, bring cash too because you're going to need it. Best two out of three, how's that sound huh? Put some money with your mouth.
Re: Wheel Stands
[Re: Guitar Jones]
#1116704
11/22/11 09:37 PM
11/22/11 09:37 PM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
Horrible..Look at the body twist..That tubechassis cas should leave straight.You are loosing more power in that flexing pipe rack you call a frame than I do pulling wheelies.2600# tube chassis car that runs 9.75 VS a 3134 Lb car with mini tubs and a 10.5 tire that easly run s 10.0s( it as fast as the car is legal to go)You do the math who makes more power. No I'm not driving to Flordia. Eddy heads 11.to 1 soild cam. http://youtu.be/TwRs1Z5i7WA
Re: Wheel Stands
[Re: gregsdart]
#1116707
11/22/11 09:53 PM
11/22/11 09:53 PM
WheelsUp73
California, USA!!!
Gang, I think we are getting away from the OP's desired reply's hear. Time to call it a day. If it doesn't directly answer one of the Op's questions, then it should be taken elsewhere.
You are 100 percent correct..My apologys to the board. I'm done here.
Re: Wheel Stands
[Re: WheelsUp73]
#1116709
11/22/11 10:03 PM
11/22/11 10:03 PM
Lisa, Keep doing what your doing.Your a great racer with a great car that works.
Re: Wheel Stands
[Re: Evil Spirit]
#1116710
11/22/11 10:25 PM
11/22/11 10:25 PM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
Motorcycles follow the same laws of physics that a car does; H/P, traction, center of gravity, instant center, suspension attachment points, etc. You will NEVER see a motorcycle make it's fastest/quickest pass with the front wheel 4' in the air. One of the first things that high H/P bikes get is a longer swingarm - to control the wheelstand. It's not because they don't have the "stones" to ride it out - they are simply faster not wasting power lifting the front end and the on the additional air drag that the larger frontal area creates.
Wheelstands are the result of a balance point - the rear tires. The higher the front wheels are in the air - IT TAKES LESS H/P TO KEEP THEM THERE. Again physics. I could type examples all day, but the bottom line is any power used to lift the front of the car is wasted - the lower you can keep the front anD set the rear suspension, the faster you will go.
Do big wheelstands look cool? ABSOLUTELY! Is there a trick to doing them? ABSOLUTELY! Fastest way down the track? NOT A CHANCE!
Lisa........... You picking on the boys again?!?!?!.... You Go Girl!!!!
Re: Wheel Stands
[Re: WheelsUp73]
#1116711
11/22/11 10:59 PM
11/22/11 10:59 PM
Posts: 3,396 Pa
Hot 340
Pa
And if your lexan door windowed car weighs 3100 lbs Ill eat my hat. lol. Who cares if she's losing et with wheelies? Sound like a bunch of pro-stockers on here. Most people forgot what drag racing is about.
Re: Wheel Stands
[Re: Hot 340]
#1116712
11/22/11 11:03 PM
11/22/11 11:03 PM
Guitar Jones
Hmm, my car still has all the factory glass in it, steel doors and the windows still roll up and down. Door locks work too.
Re: Wheel Stands
[Re: Guitar Jones]
#1116713
11/22/11 11:04 PM
11/22/11 11:04 PM
Posts: 3,396 Pa
Hot 340
Pa
not you
Re: Wheel Stands
[Re: Hot 340]
#1116714
11/22/11 11:06 PM
11/22/11 11:06 PM
Guitar Jones
Yeah, I got that. Just sayin'.
Re: Wheel Stands
[Re: Guitar Jones]
#1116715
11/22/11 11:07 PM
11/22/11 11:07 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
Wow, you need more air in the rear tires!
