Re: Wheel Stands
[Re: Guitar Jones]
#1116716
11/22/11 11:09 PM
11/22/11 11:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hmm, my car still has all the factory glass in it, steel doors and the windows still roll up and down. Door locks work too.
I sure would raise the tire pressure
Re: Wheel Stands
[Re: moparguy7074]
#1116717
11/22/11 11:10 PM
11/22/11 11:10 PM
Posts: 20,659 in a cattle trailer down by th...
Guitar Jones
There's actually 8 pounds in there but you know how that goes. Hurry up to the lanes and wait for two hours while they clean up the last Chevy oil down.
Re: Wheel Stands
[Re: Guitar Jones]
#1116718
11/22/11 11:17 PM
11/22/11 11:17 PM
MR_P_BODY
I air up the tires about a 1/4# to 1/2# high then set them in the lanes as the lane starts to move... but I run tubes so they tend to build pressure in the sun
Re: Wheel Stands
[Re: MR_P_BODY]
#1116719
11/22/11 11:32 PM
11/22/11 11:32 PM
Guitar Jones
Yeah I don't run tubes so they tend to leak down. I had no crew with me that year and the trailer was too far away so you get what you get. The car will still work fine from 9 to 7.5 psi so it's not that big of a deal.
Re: Wheel Stands
[Re: WheelsUp73]
#1116720
11/23/11 02:34 PM
11/23/11 02:34 PM
Posts: 2,007 Apollo, PA.
B1MAXX
Apollo, PA.
Are the tubular upper arms demensionally differt from stock? I end up pulling my hair out trying to accomodate toe and camber movements through out range. I just get it close and give up.
Yes they allow for alot more adjustment.I now have 6 degrees of caster and I am able to set camber anywhere I want it.Its good money spent.
Thanks for the info.......
Re: Wheel Stands
[Re: maximum entropy]
#1116726
11/23/11 09:55 PM
11/23/11 09:55 PM
Posts: 3,396 Pa
Hot 340
Pa
Most people forgot what drag racing is about.
Last I checked, it was about going the FASTEST, not the HIGHEST.
i'm a bracket racer, so it's about being the most consistent driver in the most consistent car.
You're both wrong. Its about having a good time.
Re: Wheel Stands
[Re: justinp61]
#1116728
11/23/11 11:03 PM
11/23/11 11:03 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
Each car, and the track(s) racers attend, are different. The setup to hook, and produce killer package numbers, vary greatly. Of course, I'm referring to et racers. The heads up folks will have a different need. To try and state an absolute, will always have both benefactors, and detractors.
Re: Wheel Stands
[Re: Hot 340]
#1116729
11/23/11 11:03 PM
11/23/11 11:03 PM
Posts: 5,895 Florida
Locomotion
Nope, you are ALL wrong. The correct answer is "D" - All of the above.....and then some!
Re: Wheel Stands
[Re: SuperStockWagon]
#1116731
11/24/11 01:26 AM
11/24/11 01:26 AM
MR_P_BODY
Ya...nothing more boring than a couple of big block 4spd Stock Eliminator cars wasting time(and et)putting those frontrunners so high in the air! Sheesh,nothing disgusts fans and drivers more than this kind of unsavory behavior!! Ever wonder why Super Stock is voted the most popular sportsman class in drag racing year in and year out by the fans?? Hmmmm, I say hang em high!!!
Yeah those stands look full to me.... dont worry, I like them also
Re: Wheel Stands
[Re: MR_P_BODY]
#1116732
11/24/11 01:48 AM
11/24/11 01:48 AM
Posts: 673 Emmett, Idaho
SuperStockWagon
Emmett, Idaho
Class eliminations during the week tend to look that way..a lot of great racing missed by the masses!
Re: Wheel Stands
#1116733
11/24/11 02:20 AM
11/24/11 02:20 AM
Posts: 380 S.W.Conn.
1968beepbeep
S.W.Conn.
Nothin' like Frank Lupo's Hemi Dodge ridin' the rear bumper! (The Fairbanks Racing Automatics car)
Re: Wheel Stands
[Re: 1968beepbeep]
#1116735
11/24/11 11:48 AM
11/24/11 11:48 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
If the front tires are off the ground you have 100% weight transfer,doesn't matter if it's 1" or a foot.
