Another “what will it run?” #1019876
06/24/11 07:56 PM
06/24/11 07:56 PM
New Braunfels, TX
BigBlockScamp Offline OP
New Braunfels, TX
What do you guys think this combo would be good for?
3720 lb (w/driver) Challenger
418 CI small block w/4” stroke
11.5:1 compression
Solid roller, 262/268 @ .050
Dana 60 w/4.10’s & 29.5” slick
Holley 950HP, Edelbrock Victor, ported Performer RPM heads
9.5” converter, approximately 4500 rpm stall
Pump gas
Re: Another “what will it run?” [Re: BigBlockScamp] #1019877
06/24/11 07:58 PM
06/24/11 07:58 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
11.0
Re: Another “what will it run?” [Re: Uncle Barry] #1019878
06/24/11 08:05 PM
06/24/11 08:05 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
11.50`s
Re: Another “what will it run?” [Re: 2QUICK4U] #1019879
06/24/11 08:07 PM
06/24/11 08:07 PM
boscosis Offline
super street
boscosis  Offline
super street
High 10.80's in perfect conditions.
Re: Another “what will it run?” [Re: 2QUICK4U] #1019880
06/24/11 08:08 PM
06/24/11 08:08 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
11.20's at 119 once sorted out
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Another “what will it run?” [Re: BigBlockScamp] #1019881
06/24/11 08:10 PM
06/24/11 08:10 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
How much porting in the heads? Id say if you are not running an small 1 5/8 header, and got fresh air into the carb, real low 11's.
Re: Another “what will it run?” [Re: BigBlockScamp] #1019882
06/24/11 08:39 PM
06/24/11 08:39 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
11.30 at 117
Re: Another “what will it run?” [Re: BigBlockScamp] #1019883
06/24/11 09:32 PM
06/24/11 09:32 PM
ill
dennismopar73 Offline
ill
11.5:1 compression
Pump gas
11.68-11.85 116.35 mph hows that for a guess
60' 1.63-1.67
Re: Another “what will it run?” [Re: dennismopar73] #1019884
06/24/11 09:36 PM
06/24/11 09:36 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
that weight is brutal..so i say 11.30ish
Re: Another “what will it run?” [Re: BigBlockScamp] #1019885
06/24/11 10:29 PM
06/24/11 10:29 PM
Az
Crizila Offline
Crizila  Offline
Az
11.45 - no - - wait - - 11.49.
Fastest 300
Re: Another “what will it run?” [Re: fishy340] #1019886
06/25/11 04:10 AM
06/25/11 04:10 AM
Q
Quicktree Offline
Quicktree  Offline
Q
no kidding he must weigh 500lbs
Re: Another “what will it run?” [Re: Quicktree] #1019887
06/25/11 05:08 AM
06/25/11 05:08 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Low 11s
Re: Another “what will it run?” [Re: viperblue72] #1019888
06/25/11 10:59 AM
06/25/11 10:59 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I would go with a smaller carb....a 850 is plenty.
Gives more zip in the 60 ft, where most of the race is....
Dan
Re: Another “what will it run?” [Re: BigBlockScamp] #1019889
06/26/11 12:52 AM
06/26/11 12:52 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Mid 11,s IMO, probably slower if its a untested combo.
Re: Another “what will it run?” [Re: Sport440] #1019890
06/26/11 03:56 AM
06/26/11 03:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Easy mid 11's I will say. Maybe better as them smallblock strokers just really seem to run good. Ron
Re: Another “what will it run?” [Re: 383man] #1019891
06/26/11 08:21 AM
06/26/11 08:21 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
If it doesn't go real low 11's, I think I may be real disappointed in my new motor!
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Another “what will it run?” [Re: DragDart360] #1019892
06/26/11 03:04 PM
06/26/11 03:04 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I wonder how much HP/tq the engine has at the flywheel to pull 3720 lbs. It's all a guess right now. Seems like a lot of weight to get moving. Until you get a few passes and tuned up. First pass, I'd look for a high 11. Nothing always goes right first time out. Too many stories here says different. Is it safe to say expect 115 mph and around 6800 at the traps? That may be a 11.50 pass, but Im just guessing
Re: Another “what will it run?” [Re: DragDart360] #1019893
06/26/11 03:43 PM
06/26/11 03:43 PM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
I'll say 11 teens after it's tuned.
Re: Another “what will it run?” [Re: justinp61] #1019894
07/06/11 08:17 PM
07/06/11 08:17 PM
New Braunfels, TX
New Braunfels, TX
OK, I'll own up to the post. This combo is really "416challenger" on this site and it has run a 10.87 @ 122mph in good weather (and low 11's when its 100 deg out). I've always thought it runs very well and wanted some other opinions.
