Re: Another “what will it run?”
[Re: 2QUICK4U]
#1019880
06/24/11 08:08 PM
06/24/11 08:08 PM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
11.20's at 119 once sorted out
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: BigBlockScamp]
#1019883
06/24/11 09:32 PM
06/24/11 09:32 PM
Posts: 2,177 ill
dennismopar73
ill
What do you guys think this combo would be good for? 3720 lb (w/driver) Challenger 418 CI small block w/4” stroke 11.5:1 compression Solid roller, 262/268 @ .050 Dana 60 w/4.10’s & 29.5” slick Holley 950HP, Edelbrock Victor, ported Performer RPM heads 9.5” converter, approximately 4500 rpm stall Pump gas
11.68-11.85 116.35 mph hows that for a guess 60' 1.63-1.67
[Re: BigBlockScamp]
#1019885
06/24/11 10:29 PM
06/24/11 10:29 PM
Posts: 7,506 Az
Crizila
Az
11.45 - no - - wait - - 11.49.
Fastest 300
[Re: fishy340]
#1019886
06/25/11 04:10 AM
06/25/11 04:10 AM
Quicktree
that weight is brutal..so i say 11.30ish
no kidding he must weigh 500lbs
[Re: 383man]
#1019891
06/26/11 08:21 AM
06/26/11 08:21 AM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
If it doesn't go real low 11's, I think I may be real disappointed in my new motor!
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
