Re: Another “what will it run?”
[Re: 2QUICK4U]
#1019880
06/24/11 08:08 PM
06/24/11 08:08 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
11.20's at 119 once sorted out
[Re: BigBlockScamp]
#1019883
06/24/11 09:32 PM
06/24/11 09:32 PM
Posts: 2,177 ill
dennismopar73
ill
What do you guys think this combo would be good for? 3720 lb (w/driver) Challenger 418 CI small block w/4” stroke 11.5:1 compression Solid roller, 262/268 @ .050 Dana 60 w/4.10’s & 29.5” slick Holley 950HP, Edelbrock Victor, ported Performer RPM heads 9.5” converter, approximately 4500 rpm stall Pump gas
11.68-11.85 116.35 mph hows that for a guess 60' 1.63-1.67
[Re: BigBlockScamp]
#1019885
06/24/11 10:29 PM
06/24/11 10:29 PM
Posts: 7,506 Az
Crizila
Az
11.45 - no - - wait - - 11.49.
Fastest 300
[Re: fishy340]
#1019886
06/25/11 04:10 AM
06/25/11 04:10 AM
Quicktree
that weight is brutal..so i say 11.30ish
no kidding he must weigh 500lbs
[Re: 383man]
#1019891
06/26/11 08:21 AM
06/26/11 08:21 AM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
If it doesn't go real low 11's, I think I may be real disappointed in my new motor!
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
