[quote Sounds like the converter is key. That's convincing me to spend the money for a good one for my specs
Right you are!!!
But, in Tims case (forphorty above) I believe his ETS were with.... a GER converter.
Im sure he will respond, but I believe he has a dyamic now and the car doesnt run any quicker. For sure not the general rule of thumb...But the GER worked.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,.
11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid.
12.24@110.
