poo poo intake. Get the RPM. With the thermo-q you'll need an apdapter. If you have a good WORKING thermo use if if not I'd just drop a few $$ on a 850DP. Also you'll need more stall w/ that cam, probably 3200 or so. And it will be a dog w/ 3.23, very Avg w/ 3.55's 3.91's will work. Headers? (I hope) as far as tack times, after you tune it I'd guess low 12's high 11's. Those are short tires so that will help get that thing moving.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
