Rodney I am going to say that it is probably the converter. If the transmission was slipping that bad the performance would have deteriorated by now. The torque that 572 is producing is simply over powering the converter. That thing is going to be in the 5's when you get the converter worked out.
Getting old just means you were smarter than some and luckier than others.
