Ok, but the bottom line is this is a half ass budget build. I wasn't aware that there were such crappy piston choices for 383's and that 906's were essentially useless.
My setup, with the parts I listed, with a block that's been zero decked, KB flat tops (with the 5cc or whatever size valve reliefs), closed chamber 84 cc Edelbrock heads and a .039ish head gasket sounds like it should make decent compression and quench. Does that sound about right? I'm just hoping for a decent street motor.
What is your definition of DECENT COMPRESSION ?
I think you know more about it than I do, but I was thinking 9.5-1?
The specs you give above ASSuMEing a 4.280 bore , 6cc valve canyon and a .041 head gasket , not sure what gasket is .039 , gets you 8.85 , .039 gasket is 8.88, 5cc/.041 - 8.92, 5cc/.039 - 8.96, you need to cut the heads to 76cc to get your 9.5, the 162 just plain sucks for the intended application.
The 162's are out of the question as you stated, unless used with an UNDER 78cc closed chamber type head (516's or early 60' 413's - non M-W's). The kb 400 works well with an 80 - 86 cc aluminum head, OR the "516" iron head (with larger valves) depending on how "strong" of a 383 you want!! The 375-400 hp level is easy, it's when you break the 475-500 hp level things start to get lot tougher (for streetability).
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
