Ok, I know I'm changing the direction here.
Lets say I get a pair of KB flat tops, zero deck the block, and use the closed chamber (84cc) Edelbrock heads....would that be decent as far as compression and quench? With a zero deck the piston should be as far away from the head as whatever the compressed thickness is of the head gasket I'm using right? So how about this plan? Now I just need a head gasket thickness.
Do yourself a favor and do not buy the KB162's , they [self censored] , lower in the hole than they should be and a CANYON for a valve relief , spend a little extra money and buy a set of speedpro 2315 or a few more and get a set of diamond 383 pistons if you need valve reliefs ...
