Quote: Where will the wastegate mount? It needs to see all 4 cylinders.
The wastegates will be between the turbo and engine. Im keeping the drive presssure as segregated as possible. My plan is to use 1 1/2 pipe centered between the two sides of the primerys. The wastegate supply pipe will have a divider the runs up to the wastegate valve face..... Clear as mud?
I did the same thing with my silverado, it seamed to work ok....
I am not sure what you mean by this ? ^^^^^^
You are not thinking of actually putting your blow off valves on or in your intake manifold are you ?
