Quote: Well with all that I have read here I am going to recore my OEM 22 inch. I don't think I will fool with these!!!!
Has the quality of these radiators improved since this thread was going on? I'm considering whether to have my 26" Mopar radiator boiled out or should I go with an aluminum radiator? Lots of complaints about the Champions being twisted though.
Do you currently have a fan shroud with your current original type radiator?
If so, it will not fit the Champion.
If you have to pay someone to make you a good fitting shroud for the Champion, there went of the $$$ savings of buying a Champion.
A Champion without a shroud will cool no better than a properly working equivalent brass with shroud. But the Champion will weigh a little less.
