Re: It's in, running ,has too high oil pressure**UPDATE
[Re: MR_P_BODY]
#702623
05/25/10 09:02 AM
05/25/10 09:02 AM
Posts: 3,695 nc
emarine01
nc
I really dont think its you... sounds like they have a by-pass spring issue.... you put on 2 different pumps only to have the same issue... I would say that takes you out of the problem... you could cut the by-pass spring down some.... or take the spring out of your old pump(from the original pump that worked) clean it and install it in your new pump.... and make sure the little piston/cup moves freely
We had the same problem with HV melling in our small block, we swaped springs from a old pump and have 64 psi just about all the time, when the oil gets real hot it falls to 45 @ idle and goes right back to 64 with any rpm increase, good luck , pullin the pan was a PITA but solved the problem
Entire Thread
It's in, running and has too high oil pressure???
dc426
05/19/10 09:42 PM
Re: It's in, running and has too high oil pressure???
Quicktree
05/19/10 09:44 PM
dc426
05/19/10 09:49 PM
Quicktree
05/19/10 09:56 PM
Thumperdart
05/20/10 03:23 PM
3ddart
05/21/10 01:03 AM
Thumperdart
05/21/10 03:40 AM
jamesc
05/19/10 09:56 PM
dc426
05/19/10 10:02 PM
Chris'sBarracuda
05/19/10 10:06 PM
Ron Silva
05/19/10 10:47 PM
dc426
05/19/10 10:54 PM
jamesc
05/19/10 11:01 PM
dusturbd340W5
05/19/10 11:07 PM
jamesc
05/19/10 11:55 PM
dusturbd340W5
05/20/10 12:09 AM
BobR
05/20/10 01:08 PM
StrokerDart
05/20/10 01:50 PM
dennismopar73
05/20/10 02:10 PM
dc426
05/20/10 02:55 PM
dennismopar73
05/20/10 03:44 PM
Chris'sBarracuda
05/21/10 05:33 AM
3ddart
05/25/10 02:45 AM
MR_P_BODY
05/25/10 03:09 AM
Ron Silva
05/25/10 03:24 AM
emarine01
05/25/10 01:02 PM
3ddart
05/25/10 07:49 PM
krw71ragtop
05/26/10 02:29 AM
Cab_Burge
05/26/10 02:35 AM
3ddart
06/05/10 01:07 PM
dc426
06/05/10 01:37 PM
3ddart
06/05/10 02:24 PM
BobR
05/20/10 04:03 PM
dennismopar73
05/20/10 04:24 PM
440dart
05/20/10 11:04 PM
Quicktree
05/19/10 11:26 PM
Chris'sBarracuda
05/20/10 12:18 AM
Quicktree
05/20/10 12:30 AM
blown572dart
05/20/10 12:45 AM
Post deleted by Defbob
05/20/10 12:58 AM
Leigh
05/20/10 01:05 AM
dc426
05/20/10 01:09 AM
Leigh
05/20/10 01:16 AM
jamesc
05/20/10 01:57 AM
Leigh
05/20/10 02:42 AM
flatiron
05/20/10 03:12 AM
340B5
05/20/10 04:54 AM
BeEtLeJuIcE !
05/20/10 06:12 AM
05/20/10 08:48 AM
3ddart
05/20/10 01:05 PM
05/20/10 01:49 PM
StrokerDart
05/20/10 01:53 PM
MR_P_BODY
05/20/10 02:09 PM
05/20/10 04:29 PM
340B5
05/20/10 04:42 PM
05/19/10 11:49 PM
dc426
05/20/10 12:37 AM
440Jim
05/19/10 11:00 PM
Sixpak
05/21/10 01:54 AM
polyspheric
05/21/10 02:31 PM
MR_P_BODY
05/21/10 02:44 PM
Re: It's in, running and has too high oil pressure??? *DELETED*
polyspheric
05/21/10 03:24 PM
MR_P_BODY
05/21/10 03:29 PM
3ddart
05/25/10 12:32 PM
