I really dont think its you... sounds like they have a by-pass spring issue.... you put on 2 different pumps only to have the same issue... I would say that takes you out of the problem... you could cut the by-pass spring down some.... or take the spring out of your old pump(from the original pump that worked) clean it and install it in your new pump.... and make sure the little piston/cup moves freely
