Re: It's in, running and has too high oil pressure???
[Re: polyspheric]
#702618
05/21/10 11:29 AM
05/21/10 11:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks, I was afraid I was tripping over something obvious!
My subject pump has the piston just barely sealing the passage at rest, so enlarging the existing hole can only be done to the rear in any event. A diametric increase is not a good idea since it captures the piston from cocking upward under pressure. Some pistons may be possible to just reduce the length to allow it to reach full unmask position (or modify the retainer). Check the spring to make sure it doesn't bottom out 1st, etc.
I am assuming this pump you are working with is a in pan pump so you can dump the oil
Entire Thread
dc426
05/19/10 09:42 PM
Quicktree
05/19/10 09:44 PM
dc426
05/19/10 09:49 PM
Quicktree
05/19/10 09:56 PM
Thumperdart
05/20/10 03:23 PM
3ddart
05/21/10 01:03 AM
Thumperdart
05/21/10 03:40 AM
jamesc
05/19/10 09:56 PM
dc426
05/19/10 10:02 PM
Chris'sBarracuda
05/19/10 10:06 PM
Ron Silva
05/19/10 10:47 PM
dc426
05/19/10 10:54 PM
jamesc
05/19/10 11:01 PM
dusturbd340W5
05/19/10 11:07 PM
jamesc
05/19/10 11:55 PM
dusturbd340W5
05/20/10 12:09 AM
BobR
05/20/10 01:08 PM
StrokerDart
05/20/10 01:50 PM
dennismopar73
05/20/10 02:10 PM
Re: It's in, running ,has too high oil pressure**UPDATE
dc426
05/20/10 02:55 PM
dennismopar73
05/20/10 03:44 PM
Chris'sBarracuda
05/21/10 05:33 AM
3ddart
05/25/10 02:45 AM
MR_P_BODY
05/25/10 03:09 AM
Ron Silva
05/25/10 03:24 AM
emarine01
05/25/10 01:02 PM
3ddart
05/25/10 07:49 PM
krw71ragtop
05/26/10 02:29 AM
Cab_Burge
05/26/10 02:35 AM
3ddart
06/05/10 01:07 PM
dc426
06/05/10 01:37 PM
3ddart
06/05/10 02:24 PM
BobR
05/20/10 04:03 PM
dennismopar73
05/20/10 04:24 PM
440dart
05/20/10 11:04 PM
Quicktree
05/19/10 11:26 PM
Chris'sBarracuda
05/20/10 12:18 AM
Quicktree
05/20/10 12:30 AM
blown572dart
05/20/10 12:45 AM
Post deleted by Defbob
05/20/10 12:58 AM
Leigh
05/20/10 01:05 AM
dc426
05/20/10 01:09 AM
Leigh
05/20/10 01:16 AM
jamesc
05/20/10 01:57 AM
Leigh
05/20/10 02:42 AM
flatiron
05/20/10 03:12 AM
340B5
05/20/10 04:54 AM
BeEtLeJuIcE !
05/20/10 06:12 AM
05/20/10 08:48 AM
3ddart
05/20/10 01:05 PM
05/20/10 01:49 PM
StrokerDart
05/20/10 01:53 PM
MR_P_BODY
05/20/10 02:09 PM
05/20/10 04:29 PM
340B5
05/20/10 04:42 PM
05/19/10 11:49 PM
dc426
05/20/10 12:37 AM
440Jim
05/19/10 11:00 PM
Sixpak
05/21/10 01:54 AM
polyspheric
05/21/10 02:31 PM
MR_P_BODY
05/21/10 02:44 PM
Re: It's in, running and has too high oil pressure??? *DELETED*
polyspheric
05/21/10 03:24 PM
MR_P_BODY
05/21/10 03:29 PM
3ddart
05/25/10 12:32 PM
