Why don't you research battery charging vs. ambient temps and you will UNDERSTAND why temperature compensation is important in a STOCK setup and irrelevant in a race one. It is also the only difference between the stock regulator and the MP constant voltage one.
you know up until this time where you two guys has this "discussion" I never understood what the constant voltage concept meant but now I'm grasping it. Thanks guys (I'm serious).
