not whats causing hard starting
X2. Is it cranking way slower when cold & if so are the cables clean and do you have a known good newer batt to borrow to see if that speeds it up. To test a battery you would slow charge it overnight & have a parts house test it but most dont have the right load tester so the test is invalid and it's just as easy to sub one in real quick. If it is cranking good is the choke right but from your Q I'm assuming that it is a cranking speed issue.
