Quote: He has a 69. That is the older style alt. It's not a band aid it's the best regulator to use with electronic ignition in a mopar. Do your home work.
Homework - Hell I was working on these things when you were more than likely in 3 corner pants or before. Constant regulators are not meant and never were recommended to be used on constant running applications, but on race applications where short term charge is needed to keep a battery fully charged A good charging system is all that is (should be) needed and that constant 'flow' regulator is not the answer. If you feel that it is then go for it.
