Fine but as we have all stated that regulator will not work with the newer higher out put alternators unless you ground one of the fields. And the regulator we were referring to will not work on the older style alternators. The his oem system should work fine if his battery is in good condition and the connections are clean and all grounds are good. Shouldn't need a band aide constant out put regulator on it.
