US Car Tool has nearly completed the roll cage. The main cross bar behind the front seat still has to be installed. All of the joints will be fully welded. There will be some gussets added and features such as swing-out / removable door bars and a window net.
I hate having to put one in this car. However, to be able to use it as I intend, it is required. This cage is constructed out of TIG welded chrome-moly tubing and will be NHRA and IHRA legal to a quarter mile time as fast 8.50.
A lot of care was taken to try to hide the cage as much as possible while still remaining a legal cage. The front down bars run along the A-pillars and through the top of the dash. The top bars are tucked up very close to the roof while still leaving room for a headliner. The main hoop is positioned behind the chrome strips that seal the front and rear side windows. The rear down bars follow the c-pillars as close as possible while still going through factory openings in the package tray. The door bars are shaped to meet the rules and go over the top of the factory door mounted arm rests. The car will be fitted with electric windows so there won't be any interference with the cranks. Additionally the door bars will be fitted with hinges and latches that allow the bars to either swing open or be removed entirely for street use.
In addition to the cage, these pictures show the installation of the US Car Tool sub-frame connectors. These connectors are laser cut to follow the contour of the underside of the factory floor. The combination of the roll cage and these connectors should make the unibody very stiff, at least compared to how it left the factory.
Check out more information at northernbel.com or uscartool.com
