Quote: Thanks for the update---Did you get an alignment? Any issues?
Its been aligned and everything has been fine. No bumpsteer at all, you can let go of the wheel at any speed and it will stay right where you have it pointed. Ive read that some people have had quality issues with the Chassis Tech spindles but mine were ok. Maybe I got lucky. I had to run a tap through the threads in the dust shield mounting holes to clean up the threads but other than that they were fine.
