4.5 pattern rotors: Early Dakota 2wds used this bolt pattern and had the larger outer bearing.
Think I could use that technique as a pattern for doing a 5 lug swap on a 2003 Dakota?
No, your 2003 uses a sealed hub and the older stuff is typical inner and outer bearings on a spindle shaft.
Damn. Any way around that?
