If you are stuck between the MP crate and the Blueprint, I would go with the Blueprint, there is some "slight" advantage to the MP one, but the cost is much less.
With that said you could add a roller setup for about $1000 and then you would have a roller motor...
As far as the RT heads, If I was building one I would get the Eddys over the RT heads, but that is me...
