Quote: You haven't added any aftermarket stuff hanging off the switch, have you?
Only aftermarket thing is the voltmeter I added after I by-passed the factory Amp gauge. Now that I know how to test the voltage drop at the regulator, I think I'll disconnect the voltmeter and do another drop test. It would be just my luck that I accidentally caused this whole mess by using a cheap voltmeter.
