Quote: Along with the shaker hood, you also got the trim ring with gasket, shaker bubble with shaker doors, engine callouts on the side of the bubble, dash mounted carb air cable, and appropriate air cleaner with baseplate to go with your engine/hood combo.
Did I miss anything? The idea is to list the items that came with a shaker hood that did Not come with the standard hood.
