I'm not even sure when it started frown
Wife mistakenly backing into garage door? Fix door and dented hatch on car.
Garbage disposal has been dead awhile. don't use it much but decide to Install a new one. Shakes the whole house (not quite) but wink OK upgrade and install another
Garage door (same one) stops opening. install new springs.
A day or two later the opener dies. Install new opener
Heat pump starts acting up (see other post)
Get hit with the polar Vortex.
Plumbing vents ice over (140.00) For young plumber to go up and unplug.
One ices up again but running enough hot water opens it back up.
New Vent covers ordered, here, media blasted and ready for install
Heat pump dies. takes a week or more to get a tech out.
While waiting we have a balmy 20 degree day. Remove covers to verify coils are clean etc.
tech come out, diagnoses the leak. Will take another week or so to get the leaking compressor muffler
Polar vortex finally leaves
Dealing with Medicare claims.
1st challenge was getting past the Philippines customer service. Finally called the nurses help line wink been working on these issues for 6+ months but am slowly winning ground ($$$ back)
Not sure the above time lost has been worth it
Today the snow ( about 13" total) melted t the point it revealed a 2-3 foot diameter hole over the top of the septic tank.
Called 12 or so businesses only 2 returned the calls. 1 wans 75.00 to look at it. I said i can send you a picture, he hung up. But I do have a highly reccomended person and one other coming out tomorrow. i am hoping the tank cover just vaporized and it won't be a 10K fix.
I am likely forgetting a few things due to all the fun frown
I do not recall screwing anyone over so I don't think it's Karma
Thanks for reading (If you made it this far) beer
