Quote
Might be close to a HXL lobe. Lobe 2233 is 303 advertised, 274@050 and 197@200 with 454 lobe lift.
Let me quantify my previous statement………
It seems like a pretty quick lobe for a combo using large steel valves, 1.75 rockers, and springs that are only 600lbs open.
I’m not going to second guess Kaase, so the proof of concept will be told on the dyno.
That being said, I don’t feel like the cam(from what we can tell thus far) and the springs/RR are that well matched.
If after a couple of hundred trouble free 1/4 mile passes, and the springs still test good afterward……..then it can be said the combo is well sorted out.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
