If you are still running an Amp gauge, make sure that you have a good fire extinguisher ! I suggest that you bypass the Amp gauge and install a Volt meter.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
