Originally Posted by GTSDart340
Originally Posted by DaveRS23
Pedal Commander is a very cool item, it really changes the character of the vehicle you install it on. Normally, the factory settings controls the throttle opening rate no matter how quickly the pedal is pushed. When the PCs are dialed up, the responsiveness of the vehicle is amazing. YOU actually have control over how much and how quick the throttle is opened. And depending on the particular unit chosen, most have many settings available, including slowing the response of the throttle. In certain hands and in certain weather, that can be a real benefit, too.
A while back, I installed one for a friend who has a '14 5.7 Charger. When turned up, the car felt like we had went from 2.76 gears to 3.91s. Or from a 318 to a 360. It was a tire fryer deluxe. I can't say that the car was any faster, but it really felt much, much faster. Like a different car entirely. And while I have installed several, I have never had one to the drag strip to compare actual performance difference. As peppy as the PCs make the car feel, they may just have some additional performance benefits, too.
The only down side in my opinion, is the cost. If they were more modestly priced, I would have one on every vehicle I own. They are a lot of fun.
drive
www.youtube.com/watch?v=zFI4-L--rAk
https://www.youtube.com/watch?v=cE4eCB0CIJU
https://www.youtube.com/watch?v=3vpgY5Ly1ZQ
The PC does not make the car any faster. All it does is increase the throttle voltage, but it can't make the throttle open any further than 100%. It only causes the voltage to get there faster. Your foot does the same thing, you just have to push the pedal down harder/further. As I stated above, it's a waste of money.
You must have never driven vehicles with one of these units on them. Or watched some of the Youtube videos. The difference can be quite dramatic. While you have a point that they don't bring more throttle to the party, they do bring the throttle on as fast as YOU want rather than as fast as the manufacturer wants. And that is a big difference. And they may help with E.T. at the track because you can bring more throttle in faster at the hit. That should help the 60' and thereby the E.T. If the traction is there to hold the stronger hit. MPH will probably be the same, but seat of the pants and E.T. should improve.
One other aspect that I do like is that you can not only speed the response time up, but you can also slow it down. When towing or in slick conditions, that can be real handy.
But you are totally wrong when you say that it is the same if you push the pedal down harder/faster without the throttle units. Because without these units, you are only suggesting to the computer what to do, the computer is the one deciding how much/how fast. And you are again wrong to say that they are a waste of money.......for some people. Not everybody needs one. But they do deliver a real shot to the driving experience. That's for sure.
There are more choices out there now than just the Pedal Commander. And prices are coming down, too. This unit is only a couple of hundred bucks: https://www.americantrucks.com/throttle-response-controller-1218-ram-1500-ram.html
Master, again and still
