Originally Posted by AndyF
If it runs cold without a thermostat then your cooling system should be fine. Sounds like your old thermostat wasn't working properly. I had the same issue with an issue. The thermostat checked out okay when tested in hot water on the stove, but it made the engine overheat. It was a new thermostat but it didn't work properly. The next new one solved the problem. Lots of junk for sale at the auto parts store these days.
My thoughts exactly
New Stat should be here today or tomorrow
