Originally Posted By sixpakdodge
Clean neutral allows a three speed to disengage the front clutch pack at the finish line while leaving the rear clutch pack applied to prevent the rear pack from going into over-speed.
A pushbutton is not a variant as pressing neutral will unload both clutch packs, and depending on the valve body, and other pieces...leave you with an expensive puzzle to re-assemble.
thank you for this explanation ! now i understand.
beer
