Most of the time, the recommended clearance from the piston manufacturer is the minimum recommended clearance.
If that amount of oil was coming by the rings, the car should have been followed around by a continual cloud of blue smoke.
True, but he also said the exhaust guides were loose too. The piston may not have been loose enough to road fog everything, but ring seal was certainly compromised.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
