Like has been said many times already...the oil ring location isn't your problem, the 4.5" crank isn't a problem, and worn valve guides and/or valve seals won't cause as much oil consumption as you have. If the above was an issue, then my 572" hemi would have guzzled oil (all 3 "problems"), but it never has.
I still believe your issue all along has been ring seal.
