Summit $781/ea eek
Brand:Pirelli
Manufacturer's Part Number:2307500
Part Type:Tires
Product Line:Pirelli P Zero Corsa System Tires
Summit Racing Part Number:PIR-2307500
Wheel Diameter: 19 in.
Tire Size: 355/30-19
Sidewall Style: Blackwall
Tire Construction: Radial
Tire Diameter: 27.40 in.
Section Width: 14.00 in.
Minimum Recommended Wheel Width: 12.00 in.
Maximum Recommended Wheel Width: 13.00 in.
Directional: No
Speed Rating: Y
Load Index: 99
Asymmetrical Tread Pattern: No
UTQG Tread Wear Rating: 60
Traction Rating: AA
Temperature Rating: A
Tread Depth: 8/32 in.
DOT-Approved: Yes
Run-Flat Technology: No
Tube Required: No
Max Load Single (lbs): 1,709
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
