After reading QuickD100s posts on a boneyard 318 with turbo making 500 hp, i'm sold. Turbos and alky, and cubes. A family match made in heaven. I wonder what a stroked 318 (390?) with mildly worked large port heads and a cheap turbo would do before the stock block complained? 700 hp?
Gregsdart there is a member on here that has a 94 Dodge Dakota with a Setup like what you are asking. He has it for sell in the race car for sell section if you wanted to read about it. I think he said it ran hi 9 in the 1/4 and drove it around every wear. Also this is not a for sell post.
Hi, yes, that's me...lol yeah my set up is fairly simple, stroked 5.2 (388) partial filled stock block billet caps, arp studs, 9.1 compression with mildly ported Eddy heads, shifts at 6000 runs easy 10s on pump gas, the 9.97 was with a mix of race gas, its a handful/blast to drive on the street. First turbo powered car I've ever owned and I'm sold, may not ever go back to BB, currently building a 67 Dart that will also be turbo small block.
