All engine types can fail when you are trying to go like a bat outs hell. I would like to see some 10.5's under that thing!
I’ve ran 28x10.5 stiffs on the street. I’m not a fan of how they drive, and I drive this thing a lot. They do hook way better on the street. 99% of the classes I run require a dot radial. Pulling timing on the street helps hook the radials tho.
I’m hoping to test some 26” radials and see what those are all about.
