Originally Posted By rickseeman
I think distilled water is expensive, inconvenient and unnecessary.
It's 94 cents a gallon at Walmart. How cheap are you?
How often do you replace your coolant? Weekly? How inconvenient can it really be?
If you saw the mineral content in the tap water around here you'd change you thoughts.
What do you think the antifreeze makers put in their prediluted mixes? It ain't tap water.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
