A new glenray radiator usually does the trick.....some of the new rads and cores are so thin and light that they do not seem to work. Can confirm a local here has same setup in a bird, 956 rad, fixed 7 blade fan and it never sees 200, I have driven it runs 180 all day down the highway, also a standard bore motor.
