Why don't we ever consider the fuel mixture? If it is lean it will run hot no matter whaT. I had it happen. I bought the correct numbers carb for a 440 R/T. Installed a kit and put it on there. The car ran hot all the time. But it ran nicely, didn't seem lean. Turns out it had the wrong jets inside. I knew this car ran cool before the carb change.
