you want the centerline of the crankshaft and the centerline of the rear axle pinion parrallel under power. So you build it with the front of the pinion angled down 2-7 degrees in relation to the crank centerline, depending on the type of suspension and the power.
popcorn
[img]http://i.imgur.com/boeexFms.jpg[/img]
31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
