This works for antique furniture with worn out holes for caster wheels too.
Over drill the hole, apply glue to a dowel of the same species, tap in, trim flat.
When the glue is try you can re-drill the correct size hole for the caster wheel. i've also done the exact same process with a hardwood dowel rod in the maple neck on my bass guitar...40yrs of people pulling the neck off for various reasons.. Wood glue and tooth picks work for that and it's a lot easier.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
