I have these J-heads that I'd like to clean up and get ready to put to use and there's this lovely valve cover bolt hole in it.
As you can see, it's pretty rough, but it is just a valve cover bolt, so the required torque is very low. I plan on using studs in the valve cover holes to help keep from working this one much in the future.
