Quote: Hey Stu i think you have a bolt or a nut loose somewhere...perhaps on the starter
More likely in my head.
I was thinking the nut behind the wheel might be a bit loose, too.
My son just had the same thing happen on his car, but the whole nose of the starter broke off, right back to the mounting. Jammed in the ring gear and he thought the motor had seized up.
did you sons car have a keisler tranny? johnahah may be on to something
