Quote: Check your torque converter bolts. Did you take down the driveshaft and check the u joints??
No i have only visually checked the driveshaft and u-joints and all looked fine. I recently had a new 4-speed automatic installed though and i got all new u-joints and a new driveshart. I can pull the inspection cover and check the bolts on the torque convertor if that is what you mean.
