Thanks Dartman: I will go get one of those bits in the morning.
I’m going to check runout on my drill press as well.
Going to dial indicate my axle ends/.
Put studs back in and run those- Think Andy had a good idea in checking to make sure I don’t have problem I could correct wrongly .
The bit issue makes sense as well.
Might be an error on my end by using a regular ( but new! Grin) bit .
I appreciate the help - truly .
