run a reamer thru the holes, I had to do this after using the 1/2 studs with the shank style lug nut's and they swelled the holes in the wheels slightly,I used the moroso 5/8 stud kit,,strange has brake hats that will fit 5/8 studs kit, at least mine did, I really like mine, I bought the complete front and rear kit including the matching master cylander.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
