I have a question: When you disconnected the speedo did you only disconnect at dash??? I'm asking because then the cable would still be turning and cables sometimes make weird sounds... Ron
It would be much easier to disconnect at the transmission, eh? Yep. Yep, it was. The goal was to eliminate the cable as a possible source of the noise, after all. Only one way to do that.
The speedometer gear was also removed at one point to eliminate it as well. Nada.
