Originally Posted By Mr onetwo
Best thing to do is find 1993 W150 or W250 360/518 4wd truck that is rotted out and cheap.Everything you will need is there.W250 will have Dana 60 which is a plus.
That is exactly what I did. Bought a totaled 93 Ramcharger and put the drivetrain in my 75 Trailduster
Originally Posted By bbtrux
Id find a running rusty 91-93 truck. Use the engine, trans, transfer case and maybe driveshafts ,then swap 80-93 knuckles and eliminate the full time garbage.
Thanks so much, I am going to look into that angle.
