Re: Starting on my 79 W150, could use some advice, ideas, help
[Re: ruderunner]
#2475398
04/01/18 03:01 PM
04/01/18 03:01 PM
Posts: 1,615 Table Rock Lake Missouri
furious
G3 swap has been done a few times, Mounting it in is the easy part,hardest part is deciding on Carb Vs Fuel injection....stay away from the 545 trans too many issues better off with a 727 518/46RH or any manual trans http://bouchillonperformance.com/inc/sdetail/669/742A316/360 Magnum, is an easier swap Thanks! Could I use the 727 that is already in the truck along with the converter? Easiest fuel injection and overdrive swap would be from 90-93 pickup or ramcharger. Dakota can be used but needs transfer case or front axle swap. Next easiest is 94-97 but need more electrical interface work and either transfer case or front axle swap.
In any of the above you lose full time 4wd transfer case. Up to you if you want to swap the front axle for something with locking hubs which will necessitate a matching rear axle... Thank you! I really want to keep the current transfer case and front end if possible.
Entire Thread
furious
03/31/18 02:17 PM
Guitar Jones
03/31/18 05:11 PM
furious
03/31/18 07:00 PM
QuickDodge
04/01/18 03:52 PM
furious
04/01/18 04:22 PM
ric3xrt
04/01/18 04:30 PM
NV69B7RR
04/01/18 04:33 PM
ruderunner
04/01/18 05:08 PM
furious
04/01/18 07:01 PM
ruderunner
04/01/18 09:44 PM
Mr onetwo
04/02/18 08:44 AM
Morty426
04/02/18 11:55 AM
bbtrux
04/02/18 02:14 PM
furious
04/06/18 12:51 PM
jerseybud
04/06/18 01:39 PM
furious
04/06/18 02:21 PM
jerseybud
04/07/18 12:51 AM
furious
04/07/18 01:43 AM
larrymopar360
04/07/18 08:48 PM
440_Offroader
04/08/18 12:03 AM
ruderunner
04/07/18 01:34 PM
Mr onetwo
04/07/18 02:18 PM
4x4 Roundup
04/07/18 11:50 PM
buildanother
04/08/18 12:56 AM
furious
04/08/18 01:30 AM
buildanother
04/08/18 01:58 AM
furious
04/08/18 01:26 AM
4x4 Roundup
04/08/18 02:15 AM
larrymopar360
04/08/18 07:20 PM
demon
04/08/18 02:40 AM
furious
04/08/18 03:24 AM
4x4 Roundup
04/08/18 04:23 AM
furious
04/08/18 05:16 AM
Mr onetwo
04/11/18 12:03 PM
geo.
04/12/18 01:29 AM
furious
04/13/18 04:10 AM
AdventurerSport
05/03/18 09:43 PM
furious
05/04/18 12:44 PM
furious
04/15/18 02:52 AM
buildanother
04/15/18 03:07 AM
furious
04/15/18 03:32 AM
4x4 Roundup
04/18/18 03:33 AM
larrymopar360
04/15/18 08:11 PM
furious
04/16/18 01:50 AM
ric3xrt
04/18/18 12:31 PM
furious
04/21/18 01:04 PM
larrymopar360
04/28/18 05:09 AM
furious
05/03/18 07:57 PM
larrymopar360
05/05/18 09:50 PM
furious
05/06/18 03:43 PM
furious
05/07/18 01:23 AM
larrymopar360
05/07/18 02:25 AM
furious
05/13/18 09:12 PM
larrymopar360
05/15/18 10:56 PM
NV69B7RR
05/18/18 05:06 AM
furious
06/01/18 02:34 PM
ric3xrt
06/02/18 01:25 PM
furious
06/02/18 03:34 PM
4x4 Roundup
06/14/18 02:49 AM
furious
06/16/18 02:46 AM
furious
08/16/18 01:43 AM
larrymopar360
08/17/18 11:32 PM
furious
08/18/18 04:29 AM
furious
04/11/20 01:00 AM
furious
04/11/20 01:15 AM
poorboy
04/11/20 01:48 AM
ruderunner
04/11/20 11:47 AM
larrymopar360
04/11/20 05:48 PM
furious
05/02/20 12:44 AM
buildanother
05/02/20 02:14 AM
furious
04/11/20 08:49 PM
redraptor
04/11/20 11:23 AM
furious
05/02/20 12:20 AM
