... It was a Q950 Stock jetting was way to rich...
How much did you have to lean it out from the standard tune? I'm a little surprised you said it was too rich from what I recall the out-of-the-box settings are.
I believe it was 4 front and rear
I am not surprised now by this . I had to pull 4 or 5 jets out of the front and maybe 2 rear when I went from 440ci to 505ci. Motor just works the carb harder especially if carburation is a little undersized .
Tex
PS : my 505 with a hair more comp and bit more cam makes 600-620 FWHP . With a 4150 carb , mufflers and exhaust to diff . I am not sure this one will go too much more .
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
